4% used only 50% free ?????
Discussion in 'Satellite TV, Sky TV & FreeSat' started by davecrow27, Jul 8, 2005.
  1. davecrow27
    davecrow27
    My mate has sky plus and on his hard drive it says he has 4% used but only 50% left,just wondering why this is and is there anything we could do like formatting the hd again to get back to 100%.
  2. Clabs
    Clabs
    Nov 5, 2003
    135
    +7
    Hi Dave
    Your mate should try a planner rebuild from the secret installer menu.
    Press the Services button on the remote then press 4,0,1 and finally select. (Pressing 0 and 1 won't appear to change anything on screen but once you press select the installer menu will appear).
    Choose option 7 - Sky+ Planner Rebuild. This should sort the "missing" space. It should also not delete any previously recorded material.
    If that doesn't work, he should try option 8 from the installer menu but be warned - this will erase any previously recorded material.
    Hope that helps. Clabs
