4 pole 3.5mm plug to 3 phono
Discussion in 'Cables & Switches' started by Ultraviolet, Feb 1, 2005.
  1. Ultraviolet
    Ultraviolet
    Nov 16, 2004
    143
    All
    I need a high quality 4 pole 3.5mm plug to 3 phono to connect my DDTS-100 decoder to my amps.
    The connections are for centre front, centre rear and subwoofer out.
    The only half decent audio-only cable I can find is:
    http://www.audiovisualonline.co.uk/....5mm-4-pole-jack-to-3-phono-1.5m/display.html
    but this is for 2 x audio plus 1 x composite video, which is not exactly what I'm after (as all my connections are audio)
    the other alternate is bespoke, but these run to around £75.
    Any ideas where I can look for something in between?
    Neil
  2. MickB
    MickB
    May 15, 2004
    518
    28
    Hanslope,Bucks
    +37
    Neil,
    I have the same problem. Do you use a normal (3 pole)-> 2 phono for the other 2 cables (ie front & rear), and a 4 pole-> 3 phono for the 3rd connection?
    If so, did you have any luck in finding a suitable cable?
    Thanks,
    Mick
  3. T0rNaDo
    T0rNaDo
    Sep 25, 2005
    7,889
    Essex
    +793
    have u tried maplins ?
    they do lots of different leads.
    and if they dont do one, then they more then likey do the components.
    so you could make up ur own lead the length you need.
    if ur handy with soldiering iron. :)
