4 ohm v 8 ohm?
Discussion in 'Home Cinema Speakers' started by unrealdave, Mar 7, 2005.
  1. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    SOme advice sought as I am thinking of putting some Celestion A1's (4 ohms) onto my Arcam AVR 100 along with an A6s and some mission rears and center (8 ohms).
    Some guy told me not to take any notice and mix them with no worries but I have amps that need switching to 4 or 8 ohms so what is the science behind this?
    cheers
    dave
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Those Celestion speakers are allegedly excellent but very difficult to drive. I would set your amps to the 4ohm setting.
    All this does (usually) is reduce the internal voltage rail for the power supply to help keep the current within safe levels. The 4ohm speakers will need far more current but mixing them shouldn't be a problem at all as it's only really a safety feature which helps prevent the internal protection circuits kicking in when you don't want them to. :)
  3. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    Thanks John
    I've set them up now and they sound great after messing round with position. I've set the amp to 4 ohms. Cheers
  4. Smurfin
    Smurfin
    Aug 13, 2002
    21,469
    +4,402
    Dave
    your Arcam AVR100 won't do the A1s justice, I can tell you! They are absolute beasts to drive, I'm sure I read somewhere that they dip even to 2ohms at times, which is a severe load for an integrated amp to handle! (though if you never play movies or music loud I doubt it would be a problem).
    My old Rotel RMB-1075 drove mine ok, but I then heard them on the end of a Parasound A51 and they sounded out of this world. So when you can...best upgrade that amplification:)
  5. Steve N
    Steve N
    Feb 3, 2005
    10,958
    Peterborough
    +2,402
    Would this comment apply to all integrated amps. I have a denon A1 SE which recommends speakers be 8 ohms but my speakers are Kef Refs which are mainly 4 ohms. Advice at the time of purchase was that it doesn't really matter and denon are just playing safe.
  6. Londondecca
    Londondecca
    Dec 21, 2003
    2,105
    +108
    Completely agree, the A1's are great HiFi speakers which would test any system. Not only in electrical terms but acoustical.
  7. Smurfin
    Smurfin
    Aug 13, 2002
    21,469
    +4,402
    Yes and no...when you're in flagship integrated territory such as the amp you mention, sure it will drive them fine. But with the A1s, you're talking SERIOUS power requirements to get them singing at their best, and the A1SE will fall short here.
  8. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    from what you guys say it looks as if i aint getting the best from the speakers. I also have an alpha 10 which I was thinking of putting on the A1's, feeding it from the outs on the avr100. Any thoughts?
  9. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I have edited the above posts to correct the quote tags only.
    Reiner
