4 ohm & 8 ohm share!
Discussion in 'AV Receivers & Amplifiers' started by OnTheFly, May 24, 2003.
  1. OnTheFly
    OnTheFly
    Jul 2, 2002
    2,871
    83
    Everywhere
    +105
    Would 4 ohm & 8 ohm speakers sharing a Rotel 1075 present any problems? Of course the salesman said not! He sounded ever so convincing.:suicide:
  2. ChrisNic
    ChrisNic
    May 11, 2003
    1,698
    48
    Thame
    +62
    No it shouldnt. The rotel has plennty of grunt and could run a set of 4 ohm speakers so mixing wont be a problem.
  3. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    Do you mean running a 4ohm on one channel and an 8ohm on another channel ... or running 2 speakers off 1 channel of the amp?
    Vikki
  4. OnTheFly
    OnTheFly
    Jul 2, 2002
    2,871
    83
    Everywhere
    +105
    sounddog: 'Do you mean running a 4ohm on one channel and an 8ohm on another channel'
    I will be running 3 x 8 ohm speakers & 2 x 4 ohm speakers. All via the Rotel 1075..............:smashin:
  5. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    That will be fine OTF ... just was making sure you ween't wanting to run 2 pairs of speakers off 1 pair of amps (if you get my drift) ... which would be a (relatively) bad thing (TM)
