B
Bob 5000
I have recently moved into a house built 20 years ago. The house has 4 TV out faceplates. Standard 75 Ohm coax was run in the walls when the house was built. The house has an aerial in the loft but when I moved in none of the aerial leads where connected. I have since installed a 4 way masthead amplifier to feed the four outlets. Also on the house is a minidish with a single LNB.
What I would like to do is get an independant satellite feed to each of the existing tv points.
I am not too well up on satellite installation but have come up with the following plan and would like feedback / comments on its viability and suggestions if this is not the best way to implement this.
My plan is to fit a quad LNB to the satellite dish and feed the four cables into the loft. Buy four diplexers and combine one satellite feed and one tv feed from the masthead amplifier and output this into an exisiting coax cable that feeds an exsiting faceplate. Repeat this four times for the four sat feeds and the four tv feeds into the exsiting cabling feeding the faceplates. Replace all four faceplates with tv / sat spliter faceplates.
Initial thougts are
Is this the best method to achieve what I want and will it work as expected? (Plan is to have freesat boxes for now, but also assume that If I do have Sky then I am not bothered about having Sky+ anywhere)
Is the existing cable Ok to run the diplexed feeds? From what I have seen opinion seems divided, would it have to be a case of suck it and see and hope that it will be OK and that I won't have to rip out the exisiting cabling.
Sorry if this is a bit long but wanted to get as much info into post as possible up front to avoid lots of questions later.
Thanks in advance
Initial thougts are
Thanks in advance
