4 in 1 - TV, FM, DAB, D-Sat
Discussion in 'Cables & Switches' started by ianh64, Sep 9, 2004.
  1. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    I currently have a single downlead MUXing D-TV and FM. I am looking to replace the downlead and connectors as the old ones are probably 30 years old.
    Is it possible to MUX D-TV, FM, DAB and D-Sat in a single downlead or am I asking too much? The latter are for possible future use.
    What down lead is recommended, I hear about CT100, CT125, CT16? and the like. What are the differences? Some appear to be dimensionally larger - will this be a problem finding the relevant connectors.
    What connectors will I need. Are screened 4-1 MUX boxes, flush and surface mount available.
    I guess it would be best to get a professional to install. Can anyone recommend one in the N Surrey/SW London area? Preferably one that can also install a satellite dish, optimise my aeriel and will do a proper job with the cable runs.
    Ian
  2. bobbypunk
    bobbypunk
    it is definately possible as we have one wired at my work place, but the only ones we can sell are Very expensive. I know that the ones we use are much cheaper but no idea where you can get them or models etc...
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    How much is "very expensive" ?
    -Ian
  4. bobbypunk
    bobbypunk
    just checked and there doesn't seem to be an expensive one it is actually pretty cheap.
    Channel Plus 2514 costs about £15
    You would need to find a supplier and to check for 100% that this does what you want, but I think it is!
  5. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Thanks. Not quite what I was after, but the part code allowed me a good starting point for web search.
    Think im going to get an expert in to quote for a loft distribution amplifier, down link and room based Sat/TV/FM-DAB socket and the possibility of getting a small satellite dish installed for non $ky subscription channels.
    -Ian
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    check out local CAI installer www.cai.org i think. You can use these distributed around a the house but you really need a central point in the loft etc then you can use one cable to each room.
  7. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Thanks, im now a fully signed up member of the Christian Assemblies International organisiation :eek: The link is www.cai.org.uk but thanks for the pointer, there an installer near where I live.
    -Ian
