4 foot sky remote ?
Discussion in 'Sky Digital TV Forum' started by joseph, May 9, 2003.
  1. joseph
    joseph
    After installing a amplifier, which is fed from my rf2 output from my sky digi box, (this feeds 4 seperate tv,s from the outputs of the amp ), my remote control on one of the tvs will not change channel etc unless you are within 4 foot of it , it worked fine before (i,ve changed batteries, changed remote etc)
    The light on the magic eye is lit and when you point the remote at the magic eye the eye flash,s but won,t work unless you are 4 foot away,tried the remote on a seperate eye in another room and it works fine .
    How many eyes can you have running from a sky box, the amp i have is a 6 way one with magic eye by pass many thanks j
  2. manny
    manny
    Jan 11, 2003
    182
    ireland
    aw heck, when i saw the title of the thread i thought you could get a 4 foot long sky remote! that would be...interesting...
  3. joseph
    joseph
    I thought i would make it sound more exciting than the actual problem i was having.
  4. Fernsehman
    Fernsehman
    You haven't made it clear but I assume that you have a SkyLink compatible 6-way Amp with a SkyLink remote extender ("eye") in each room.
    You don't appear to have swapped the SkyLink with one from another room. Try that.
    The other thing to try is disconnecting the SkyLink from the TV set. Obviously you won't then see the picture but you can try the remote at ten feet range then reconnect the cable to see if it's changed channel. If this allows it to work, there's a bodge you can do.
    Finally, you must use double-shielded coaxial cable for ALL connections, including the lead from the SkyLink to the TV aerial socket. (Don't plug it directly into the aerial socket - you'll damage it).
    If your SkyLinks are the Global "TVlink" sort, I've heard they are inherently unreliable. I use a "DIGiLink" from satcure.
    Fman
  5. joseph
    joseph
    Hi i read your post on my 4 foot remote ,i cured that problem ,i cleaned the lens on the magic eye (wife had been polishing with spray and it was coated!
    I have another problem ! my portable in my sons bedroom won,t change channel with the magic eye fitted ? If you disconnect from tv it works but when you reconnect it won,t change channel many thanks j
  6. simon123
    simon123
    May 14, 2003
    301
    +8
    read my reply on the original posy hope it helps
  7. Fernsehman
    Fernsehman
    http://www.satcure.co.uk/tech/tvlink.htm
