4:3 on a widescreen PW7
Discussion in 'Plasma TVs Forum' started by David, Nov 16, 2004.
  1. David
    David
    Nov 26, 2002
    221
    16
    London
    I haven't been able to set up my new th37pw7b yet, (building works) but I was a bit worried by a mate who said I should be careful about watching too much 4:3 material on the screen (especially at the beginning) because of screen burn and getting bands down the sides. Is this a problem and if so should I try to stretch the image on the screen to avoid it?
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    All jealous mates try to tell you you've bought a problem. This is not really an issue on a Panasonic screen, they have worked hard to make them robust. You have to take the mickey to damage them, be sensible, but relax.
  3. David
    David
    Nov 26, 2002
    221
    16
    London
    Thanks, I'm reassured. I still watch mostly terrestrial TV which will now be via the freeview box.
  4. MuffKing
    MuffKing
    You can even out the brightness across the screen BTW by changing the brightness level of the side bars to match the brightness level of the picture area on these :)
