4:3 not 16:9
Discussion in 'Blu-ray & DVD Players & Recorders' started by idolm, Sep 8, 2007.
  1. idolm
    idolm
    Apr 12, 2007
    84
    Pan 26LXD70
    Pan EZ27EB
    Connected via HDMI only
    Hi,Sorry for posting another question.When I play back a recording,it is displayed in 4:3,not 16:9.Original DVD's are displayed in 16:9.Any ideas please.
    Cheers:)
  2. Adrian_F
    Adrian_F
    Jun 29, 2007
    1,426
    83
    +293
    I don't connect via HDMI on my EX77 but have you tried altering the "Aspect for 4:3 Video" in the HDMI settings, to see if this makes a difference ? The manual seems to imply this should be set to 16:9 . ( Functions - To Others - Setup - Connection).
  3. trevor g
    trevor g
    hi, welcome to the forums. i have the ez27 and connected with hdmi cable
    supplied with the unit.for 16:9 set the hdmi output to 576p and you will have
    everything in widescreen. the automatic and 720p/1080p will show 4:3 on
    some programs particually annoying when recording from the epg.
    kind regards trevor.
  4. idolm
    idolm
    Apr 12, 2007
    84
    Hello Adrian F and trevor g :hiya:
    Followed the advice you both gave,with the following results.
    Adrain F,I set the screen size to 16:9 originally,changed it to 4:3 as you suggested.All recorded programs were shown full screen.But how does this effect programs broadcast in widescreen?.
    trevor g,Changed the output to 576p,with the original screen size of 16:9.The program was full screen.
    This creates a dilemma,both ways solve the problem,but which is the best solution?.
    Thank you both for your kind help,it is appreciated.Cheers,Mike:thumbsup:
  5. trevor g
    trevor g
    hello again, 576p solved the problem for me.upscaling freeview to720/1080
    will give no benefit over 576.changing the resoluction upwards whether set
    to 16:9 or 4:3 will always result in the black bar on a lot of chanels when
    using hdmi. at 576p the picture is lovely and every chanel in widescreen.
    it works for me. regards trevor
  6. idolm
    idolm
    Apr 12, 2007
    84
    Hi trevor g ,
    Will do as you suggest .Thanks:thumbsup:
