4:3 border colour on pw6
Discussion in 'Plasma TVs Forum' started by Koalaboy, Oct 24, 2004.
  1. Koalaboy
    Koalaboy
    Oct 19, 2004
    276
    28
    Plymouth, Devon
    +31
    Well, after a day with my PW6, I'm convinced it was the best decision I could have made. Absolutely loving the picture quality, and I haven't even got my component boards setup yet.
    The only thing bothering me at the moment are the grey borders when in 4:3 mode (I'm running RGB throught the JS RGB->VGA converter if it makes a difference).
    Is there any way to change this to black, maybe in the service menu or something, or have I got my setup jinxed somehow ?
    I don't have much 4:3 material, but it would be nice if it could be black. If this is just the way it is, then at least I know.
    Many thanks for any help.
  2. Koalaboy
    Koalaboy
    Oct 19, 2004
    276
    28
    Plymouth, Devon
    +31
    Seems I keep finding my own answers :rotfl:
    In case anyone else hits the same problem, it's the "side panel" setting in the screensaver section of set-up. Mine was on 'high' which made them ligth grey. By turning it off, they go black.
    Is there likely to be any adverse effect to turning this off ?
    Michael.
  3. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    I think grey is recommended, to prevent image retention, especially during the 'run in' period
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,425
    Somewhere in South Yorkshire
    +5,824
    Grey is indeed there to protect the Plasma phosphors from uneven ageing (aka burn-in).
    All plasmas age, all the time they are in use. The phosphors get gradually dimmer, depending on how brightly, and for how long, they are lit. If this gradual dimming occurs evenly across the whole screen, it will never become perceptible. However, if one part of the screen ages more rapidly than another, the part will, in time, become noticeably dimmer than the rest. And you see this as a permanent effect. This is what "burn-in" is. It's most often seen when you watch a digital channel with a bright white logo for prolonged periods, where the area of the logo gets darker than the surrounding due to its more rapid ageing, due in turn to its disproportionately high level of illumination.
    When watching 4x3 material with a black border, the centre piece of the screen is illuminated whereas the sides aren't. Averaged out over the length of, say a TV show or film, this has the same ageing effect, on the centre of the screen, as continuous grey (at a given level).
    So - the grey sides are there to ensure that the whole screen area ages (dims) at roughly the same rate and hence never becomes visible.
  5. Koalaboy
    Koalaboy
    Oct 19, 2004
    276
    28
    Plymouth, Devon
    +31
    Thanks for the replies.
    I've put it back to 'mid' grey, and we'll just get used to it for the odd 4:3 programs we watch.
    Thanks again. :smashin:
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,749
    The Borders
    +3,086
    mcihaelj
    If its only occasionally that you watch in 4:3 mode then you wont have any issues with the side bars set to near black - the grey bars are a must if you watch a lot of TV in 4:3 though.
    Best regards
    Joe
