3pin to IEC
Discussion in 'Cables & Switches' started by Samuelkaye2, Dec 7, 2004.
  1. Samuelkaye2
    Samuelkaye2
    Hey guys,
    Just a quick post. Does anyone know where I could get a 10m mains power cable with a 3pin standard UK plug at one end, and at the other an IEC plug. The same sort a computer runs off? I’ve tried lindy.co.uk and a few other places but can’t find anything long enough.
    Thanks for your help,
    Sam
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    I've never come across one that long. Wouldn't be hard to make yourself though if you can cope with wiring a plug.
    Just get the 2 plugs you want and some appropriately rated power cable from your local DIY/electrical store, won't work out more than a few quid either :)
