3pin plugs ,where ?
Discussion in 'Home Cinema Building DIY' started by RobsterD, Jul 7, 2003.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Can someone supply a link for purchasing 4pin molex(male/female) plugs and the 3pin plugs that are found on the end of fans that attach to motherboards.
    Located the 4 pin molex but cant find the 3-pin motherboard plugs anywhere.
    Rob
  2. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    Have a look here - if they're not quite the ones, use the categories near the top of the bage to step back a bit and poke around until you find the right ones!
  3. RobsterD
    RobsterD
    Dec 11, 2000
    870
    Southampton
    +12
    Sorted,thanks for the link !
    Rob
