3m+ 3 pin power cable
Discussion in 'Cables & Switches' started by mh8701, Mar 19, 2006.
  1. mh8701
    mh8701
    Dec 10, 2005
    239
    16
    5 amp 220-240 V
    anyone know where i can get one?
    thanks alot mh8701
  2. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    make one?
  3. mh8701
    mh8701
    Dec 10, 2005
    239
    16
    i cant im afraid, not good with that kind of stuff
  4. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Do you mean IEC or cloverleaf cable? I can't make you one, as that would open me up to all sorts of legal ramifications, however I can sell you one off the shelf and then make another one to replace my employers old one (which will then be signed off), if you catch my drift - or I can tell you exactly how to make one.
  5. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Oh, and maplins sell 3m and 5m IEC cables in black :)
  6. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    If you can wire up the 3 pin plug end of the cable you can easily do the IEC end as well, they are no different. I'm not that savvy with wiring but had no problems making one for my pj.
  7. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    I got one on ebay from this guy: http://stores.ebay.co.uk/Thudspud
    Mine was a 5m with the black braiding. Came to about £26inc and i'm pleased with it, quite sure there was a sound improvment. However this was replacing a daisy chain of old extension leads running along speaker wires
