W
Wil
I have just ordered from Amazon a triple DVD set of 3D movies which use the LCD shuttered glasses system (included)
Will it work with my Barco 801 and Lido? The Lido is the bit that makes me wonder because the glasses work by making one eye look at one field and the other eye at the other field.
Does the Lido get rid of fields per se or does it just make them look better?
Which begs the question can it be turned off if it gets in the way?
If anyone knows, please tell. If nobody knows I'll let YOU lot know in due course.
