Quantcast
3d xl box
Starry
ive just fitted a optoma 3dxl box to my 67n pj and i think it has affected the picture quality of normal tv.
is this possible or is it in my head?
thanks
toddy28
Set your sky box to 720p or update the firmware to fix the issue with the 1080i signal from sky
Starry
im using virgin tivo box, is there something i can do with that?
if i change to 720p will it effect my tv picture?
thanks for the fast reply
toddy28
Should look about the same
The update to the 3d xl box is easy look at the 3d xl owners thread for instructions
Starry
does anyone know why the optoma 3dxl owners thread has been closed?
im tyring to sort out my poor picture when running 2d through it.
the problem is lines running through the picture, more so on fast moving shots.
thanks.
Starry
Cheers lee, I found that but the only option I
can see is to post a reply and not a new thread
I'm sure I'm going to look like a numpty now
but I can't work it out /-:
Lee
Sorry not sure I understand.
If you want to post in the 3DXL part 2 thread you'd use the post reply button.
If you wanted to start a new thread then use the main projectors list...Projectors | AVForums.com - UK Online
I could be the numpty here :D
Here is a post with the firmware update link....http://www.avforums.com/forums/projectors/1412494-optoma-3dxl-owners-thread-29.html#post15285014
Starry
Ah, I see, I thought as it says reply to post
i would be replying to a question.
Thanks for the links, I'll have a look now.
