Quantcast
3d tv, normal projector
Tomc88
Hi, I've got a 51'' samsung 3d tv I want to put-up on my wall and also a spare Projector. If I where to connect them both to my amp would the projector show a 3d image like the tv does as it should just copy the signal the tv gives out? If it can be done, can someone explain how?
Geps
If everything is 3D compatible and you have a splitter that is also 3D compatible then yes.
The specs of the items will tell you what it supports.
