Quantcast
3D TV and Bluray - do I need HDMI 1.4 ?
Scooby2000
Do you need ethernet? do you need the audio return? Does your kit support 1.4?
HDMI 1.3 as long as its high speed is fine for 3D, no need for 1.4.
I only have a PS3, Panasonic BDP110 and Denon 1910 AVR, so no kit that uses 1.4, I just use optical for sound, 3D is fine. You can get players with two HDMI if you dont want to use optical for sound, 3D on a high speed 1.3 will be no different to 1.4.
brewster0101
Whats the point with ethernet over HDMI ? I have my TV and bluray connected by ethernet using a cat 6 ethernet cable. My router doesn't support ethernet over a HDMI cable! - I think I am being a tad noob with this modern tech.
Don't know what audio return is? But I guess not. I have the bluray attached to my amp with an optical cable - works fine for me.
Bluray and TV all support 1.4 - but I don't dont know if my HDMI cable is high speed. Its a few years old and was only a cheap cable.
celsius
If you bought your cable in the last couple of years there should be no problem.
If you bought your cable a few years ago there is a question mark.
But the chance is it could still be OK.
There is no such thing as 1.4 HDMI cable. It is a myth so that sales tell you so that they can get your money for a more expensive cable which works the same as £2 one. All cables sold in the last couple of years should all be high speed, cheap or otherwise.
If you see it works then it works.
If you "think" it is not that good then it may be the source, or that it may be "you".
Have you seen it, or other 3D movies, in another set up?
Do you have nother source? Another 3D BD may be?
Do a comparision.
brewster0101
Do a comparision.
I think its probably me and I literally just turned the new TV on late night and wanted to quickly see how it was. I probably need to spend time setting it up better.
Trollslayer
Sounds like Celsius has got it.
tbag21
If 1.4 cables are a myth how come when i connect my 3d blu ray player or ps3 into my 1.3 amp the devices don't recognise the tv as 3d?
SteveU30
Surely because the amp isn't 1.4 therefore doesn't support 3D pass-through?
ArmitageShanks
Yes - the problem is with the amp, NOT the cable.
As Celsius says, there's no such thing as an HDMI 1.3 or 1.4 cable. HDMI have explicitly banned cable manufacturers from labelling their cables with a version number. HDMI cables are either rated for high-speed data transfer (which you need for 3D), or they're not. Plain and simple.
There are some sub-types that allow ethernet and whatnot, but there's very little out there that needs that sort of cable.
Scooby2000
Yes sorry its not the cable its more product feature support.
What AV do you have? My Denon 1910 is a 1.3 AVR and both my PS3 and bluray player work through it to my GT30.
At the moment I have both my PS3 and player going direct to the TV and use optical for sound to the AVR. When I move and use my 5.1 more Ill likely plug them back into my AVR.
jaymac
and use optical for sound to the AVR. When I move and use my 5.1 more Ill likely plug them back into my AVR.[/QUOTE
But what about HD_master Audio you cant get that through Optical?
tbag21
I've got a Sony str-kg800. I've tried different cables and both my ps3 and blu ray player just aren't seeing the tv as 3d, I can still use the devices but the films and games dont enable the 3d, I really wish there was a way round this as at the moment I'm just using the amp for sound which is a bit of a waste. :(
Scooby2000
Its a git but I can do without for now, rooms small and now my girl lives with me its full of....stuff:rolleyes: so prob wont notice the difference....oh! and my subs now disconnected as she doesnt like it:(.....I was a man once:laugh:, never let them move in, never!, just dont do it:facepalm:
I Will be having a man pit when we have a bigger house, oh yeah.:laugh:
tbag21
Know exactly how you feel, I don't think my sub has been used in the past 8 months because of a new baby so I've resorted to headphones :( at least the missus doesn't mind my kit, she just leaves me to it. If it was up to her we'd still have a 15" portable and a VHS player!
Scooby2000
What player do you have and hows the PS3 setup?
May be the AVs too old, sorry dont know a lot about the AV side of things, my Denons an 09 dont know if 1.3 spec changed in 09 to support whats needed.
SteveU30
This thread may help a little, different people have got 3D working on various 1.3 Amps using different setting on the other equipment: http://www.avforums.com/forums/av-amplifiers-receivers/1322505-hdmi-1-3-av-amps-3d-passthrough-please-post-your-experiences-2.html
jaymac
Spent about half an hour in Currys prior to getting my gt30(elsewhere ) with him trying to convince me I could get it via Optical :)
Similar threads
Trending threads
