Top advice thereThere's always something better "just around the corner" though, isn't there?
Don't forget the newer ones, whilst they may or may not improve on the ones out now, they may also have their own faults and niggles, not to mention undoubtedly more expensive.
Of you're sure you want one, first you need to decide whether to go active or passive and go from there.
I bought an active Panasonic plasma on February, couldn't be happier with it, don't use the 3D that much to be honest though![]()
Hi All,
I am in the market for a 3D TV for my lounge.
The size I am looking at is either 46" or 55".
What are the best options to go for?
Paul
