Hello, We have a Panasonic TH-L42ET5T, (Thailand version but expect it to be similar enough to other countries versions.)
Can not get subtitles to work with 3D content, the text is unreadable as its not being handled correctly. If we switch the TV into 2D mode the subtitles appear correctly, imposed over the 2 side by side images.
We contacted Panasonic and they made some suggestions but it did not help...
"It seems there has been some success if the TV is put into side-by-side 3D manually without letting the TV auto detect. We would recommend using Google search to potentially overcome this as there are some third party 3D subtitler software packages available, however we can't take any responsibility if you chose install /use such software."
Have tried 3Dsubtitler (but this won't run on my xp pc, even the older versions?), also tried srt23Dass but gives the same results.
Any one found a way to overcome these problems
Thanks.
(PS we also have issues viewing Thai subtitles on 2D, but will worry about about that after the 3D English subs are working)
Thanks.
