3D Questions
Discussion in 'General TV Discussions Forum' started by Chrish85, Mar 5, 2013.
  1. Chrish85
    Chrish85
    Feb 25, 2013
    Hi all,
    got received my TV yet (being delivered on saturday), however I'll be playing these on an LG 55LM760T which does support mkv playback
    So I have a few 3D MKV files..
    Most are LEFT:RIGHT split, however there are also a couple that are
    TOP
    BOTTOM
    split.. whats the difference and will my TV play both with no problems or will I need to convert them to a different split type? :lease:
    Thanks for your help and sorry if this is in the wrong section, couldn't work out best place for this.
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    thread moved
    Curly
  3. Jason Shouler
    Jason Shouler
    Jan 8, 2011
    2,135
    POOLE
    +162
    These are usually referred to as H-SBS (half side by side) and H-OU (half over and under).
    Both will play fine but for best playback quality you should try to acquire H-OU if you can. Most playback problems will relate to lack of codec support and high bit rate issues which you'll quickly get used to.
  4. celsius
    celsius
    Jun 1, 2008
    458
    28
    +39
    Video will play OK
    Most mkv 3D movies have DTS audio which many TV do not support. Previous LG gerneration (LW series) do not support DTS. I do not know whether new LM series have more audio support.
    Have a look at the detail specifications on the audio codec supported.
  5. derek500
    derek500
    Dec 23, 2007
    3,746
    103
    +497
    The LM range supports DTS.
