3D player recommendations please.
Discussion in 'Blu-ray & DVD Players & Recorders' started by daveb975, Jan 9, 2012.
  1. daveb975
    daveb975
    Oct 25, 2002
    4,367
    103
    London
    +375
    I have recently upgraded to a 55" 3D TV, so would now like a Blu Ray player to go with it.
    I used to have a Denon 2200, but found it too slow to use all the time. I replaced it with a cheap Sony S370, and have found the picture and sound to be the equal of the Denon.
    My only problem with the Sony is that it has a very slight whine to it which can be annoying in quiet scenes.
    Is it worth spending £250 on a Denon 1611 or equivalent, or would a I get very similar performance from a £100 Sony S480?
    I am using my PS3 slim for 3D movies at the moment. The picture is great but the fans are too loud!
  2. mentm
    mentm
    Jun 20, 2008
    4,139
    Wiltshire
    +466
    as you find the sony's whine annoying I would suggeest the panasonic dmp bt110 which is reported to be quieter. IMHO you will get similar performance from a denon or any other player costing £250.
  3. Ian Dudley
    Ian Dudley
    Apr 28, 2006
    778
    +80
    I've just got a BDT110, upgrading from an older Sony S550, and I've been impressed with how fast it loads and it's certainly been quiet enough for me not to notice it when playing a disc. Only downside I've noticed is that the remote doesn't illuminate or have glow in the dark buttons. Might seem a trivial thing, but if you're wearing active shutter 3D glasses it's really hard to see the controls! :)
    I would also avoid all current generation (Sx80) Sony players as they have an unfixable fault with their video output which AVF note in their review of the 480.
    Sony BDP-S480 3D Blu-ray Player Review | AVForums.com - UK Online
    I also discussed it in this thread which links to some other sources on the problem.
    http://www.avforums.com/forums/blu-ray-dvd-players/1569893-sony-s480-picture-quality.html
