3D and 'after effects'
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by spacemonkee62, Oct 10, 2003.
  1. spacemonkee62
    spacemonkee62
    Could any 'after effects' users give me some advice as to which programme I should use for creating 3D Text to be imported into After Effects. I know there are only a handful of applications that can be imported as a 3D file. Which is the better?. I only really want to animate the text within 'AE'....nothing too fancy.
    Cheers.
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,167
    +1,209
    I was pretty sure that AE had a 3d text plugin knocking about.
    Maya Lightwave and 3D studio max are the ones I'm familiar with but they are all a little hi-end.
