3930 HDMI light flashing
Corrado
I have noticed that when I play a CD via the optical output with my TV switched off, the HDMI light flashes.
This makes me worry, so I turn HDMI off when playing CDs with the TV off. Do I need to turn HDMI off - does the flashing light mean danger?
lukassk
Hi !!
Most likely its only means that there is no connection between dvd HDMI terminal and TV hdmi terminal. That is it. I wouldn't worry about it.
Corrado
Hello
Ah okay, so there is no need to turn HDMI off or anything? Just let the light flash. What I was confused about was that it even flashed when I had it set to Pure Direct with Video off. I thought this turned HDMI off!?
spl23
On my 3910, the HDMI light only flashes when playing CDs if I have had the monitor turned on since powering-up the player, and have then turned it off. If I leave the monitor on, the light doesn't flash, and if I never turn it on, it doesn't flash.
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
