3910 DenonLink problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by johndonovan, Oct 26, 2004.
  1. johndonovan
    johndonovan
    I have just installed my 3910 with a 3805, connected to a 434HDE - it looks fantastic btw. I have a problem though and am asking whether someone out there knows the answer.
    When I go to the setup menu on the 3910, the digital input screen shows the option to use Denon Link, but it is "greyed" out, so that I can't select it as I scroll down. The amp shows Denon Link as the input, but I can't seem to activate it from the 3910. Is there another part of the menu which I need to change in order to activate Denon Link, or do I have a fault?
    Any help much appreciated.
  2. Messiah
    Messiah
    Apr 22, 2002
    7,620
    +338
    Make sure there is no disc in the player when you enter the setup menu. That shoukd fix it. Also, if you search there is another thread already discussing this in more detail.
  3. johndonovan
    johndonovan
    Thank you, I will try this next week when it's back up on the wall after the plasterers have been in. Thanks :thumbsup:
