3910 - 2 channel CD Playback problems
Discussion in 'Blu-ray & DVD Players & Recorders' started by rimibar, Dec 22, 2004.
  1. rimibar
    rimibar
    May 17, 2003
    424
    Cambridge
    +3
    Hi Everyone,
    Hope you can help me with this one. I am demoing a 3910 at present. It is connected via iLink for most things - but the sound that I am getting through this on CD is a bit clinical - and I am hoping that the 2 channel output may bring some warmth - problem is I can't get any sound out of it at present...
    I have set up some decent phono cables to link the 3910 to the "CD" input on my AX10i. But absolutely nothing comes through.... Is there something that I need to set on the Denon?
    I have looked through the Denon menus but most of the audio menu is greyed out.
    Can you help? Gandley - you seem pretty well placed to comment here.....!
    Thanks in advance! :thumbsup:
  2. rimibar
    rimibar
    May 17, 2003
    424
    Cambridge
    +3
    If so - your advice much needed!
    Thanks!
  3. Miniholic
    Miniholic
    Apr 26, 2001
    3,043
    The Shire
    +397
    I'm using a 3910 for CD via the analogue outputs and didn't have to do a thing, but I'm not using iLink, so could it be that this becomes the default setting when used?
  4. rimibar
    rimibar
    May 17, 2003
    424
    Cambridge
    +3
    That would the conclusion that I drew as well Mini. Surely you should be able to use both though - seems a little ridiculous!!
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    If you are using i-link or Denon Link , you can't use analogue out. You have to go into the menu & turn them off. (Believe it's part of the I-Link spec)
    I have to do the same thing on my A11
