3840 x 2160 little box follows cursor round
Discussion in 'Computer Software & Operating Systems' started by avfrms5032, Apr 5, 2016.
Tags:
  1. avfrms5032
    avfrms5032
    Jul 26, 2013
    317
    +10
    I have a GTX 980 ti everything has been fine.
    But recently when i play games at 3840 x 2160 there will be a small rectangular box a few cm below the cursor that moves with the cursor. Its different for different games, so with DAI its a box with many small different colored horizontal lines.
    I took a screenshot while in game, but the box does not appear in the screenshot.
    I have looked on the internet but cannot find any articles that deal with the problem.
    I posted the thread in this section because its not hardware, its not the TV and its not the game.
    So its either Windows or the Nvidia software.
  2. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,211
    Norfolk
    +2,341
    Screenshots are taken fairly late in the process, so not appearing on there does often point to a screen problem. From your problem description it does sound less likely, but why have you ruled out the TV entirely?
    You say this happens when you 'game at 3840x2160'. Does this also happen when gaming at a different resolution? Or running windows at 3840x2160?
    Is that the actual resolution output or are you using nVidia's DSR to render at that resolution that downscale prior to output?
    Have you tried running an OpenGL game?
  3. avfrms5032
    avfrms5032
    Jul 26, 2013
    317
    +10
    1920 x 1080 is ok, so is windows at 3840x2160.
    3840x2160 with 360 controller is ok in DAI but if i switch to KB\Mouse the box is back switching resolution to 1920 x 1080 removes the box.
    It doesnt affect all games, i was playing alice madness returns at 3840x2160 without the problem.
    It affected MTW2 for a while but then stopped.
  4. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,211
    Norfolk
    +2,341
    Did your mouse come with software that you installed? That could potentially be the issue.
  5. mjn
    mjn
    May 24, 2001
    22,723
    Herts, England
    +10,865
    Seen it before. It is a driver issue.
    Have you tried using reference drivers?
  6. avfrms5032
    avfrms5032
    Jul 26, 2013
    317
    +10
    reference drivers?
    for a Gigabyte Z97X-UD3H, those would be the gigabyte drivers ? or are the reference drivers the logitech ones
    the M/KB set is logitech, iv'e uninstalled the unifying software but the problem remains
  7. avfrms5032
    avfrms5032
    Jul 26, 2013
    317
    +10
    sorted - yes it was drivers
    thanks
