3805
Discussion in 'AV Receivers & Amplifiers' started by ISHANTY, Jul 25, 2004.
  1. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    Got my denon on friday and i have to say i'm really pleased with it apart from the remote has a mind of it's own will be sending it back for a new one i really can't wait to get the 3910 player to pair it up with
  2. Sc0rp10n
    Sc0rp10n
    have you gotten your 3910? i just ordered my denon 3805 and 3910 today from crutchfield and got the labor day 10% discount on the total order. i'd like to get your impressions on your setup. what kind of display are you hooking it up to? i'm going to get a samsung hlp6163 dlp. how are you connecting your 3910 up to your 3805? can the denon link connection be used for dolby digital on dvd movies or do you have to use the optical or coax?
  3. ISHANTY
    ISHANTY
    Sep 13, 2002
    556
    3
    28
    UK
    +66
    i have put the 3910 on hold until the have sorted out if sony will allow i-link on sacd other wise it won't be much use to me as o yet i'm not saying i won't buy it but i think it's still overpriced
