3805 tuner problem
Discussion in 'AV Receivers & Amplifiers' started by frustin, Jul 15, 2005.
  1. frustin
    frustin
    Jan 18, 2005
    74
    Braintree
    the problem is: i cant get it to work.
    I have the FM cable you get with the amp plugged in and i then did a scan of the frequencies and nothing, just low noise static.
    The core of the FM cable looks very thin, i am wondering if its because its not touching the core connection on the amp.
  2. Eddy Boy
    Eddy Boy
    Dec 9, 2004
    937
    28
    London
    +27
    Well if you're in a poor reception area then you may need a proper roof area etc.
  3. frustin
    frustin
    Jan 18, 2005
    74
    Braintree
    its fairly poor but i do get a reception from my little hand held.
