3805 Sub-woofer problem
Discussion in 'AV Receivers & Amplifiers' started by buckyb, Nov 2, 2005.
  1. buckyb
    buckyb
    :( My sub-woofer suddenly stopped working. I thought my sub went bad but when I hooked it up on my other receiver it still works. I connected my friends sub to my 3805 and that too will not work. I used both manual and auto setting (using the mic) to set up the speakers. The receiver just cannot find the sub. Is there a setting that I'm missing or not seeing? Does anyone had this problem before?
    Thanks in advance for the help!
  2. Jase
    Jase
    Mar 16, 2001
    10,960
    United Kingdom
    +3,421
    Try a Processor Reset. Hold down the Direct and Pure Direct buttons on the front panel whilst turning the Power ON and the display will flash and reset the unit. If that doesn't work then it could be the SW Pre-Out that has packed up. Just bear in mind that after resetting it you'll have to re-do all the setup again.
  3. buckyb
    buckyb
    Thanks Jase, I will try that.
