3805 speaker set up
Discussion in 'AV Receivers & Amplifiers' started by marcusa, Mar 20, 2006.
  1. marcusa
    marcusa
    Jan 20, 2006
    52
    I have just attached my new speakers (Monitor Audio GR60 fronts, Gold Centre, GR10's rear) to the 3805 and carried out the automatic EQ setup. Is that all I have to do, or are there other things I have to set up/check too?
    For example should I set the size of the speakers (currently fronts and rears are set at large, centre is small)?
    Should I have my rears plugged into the surround zone A, or the surround back?
    Anything else I should check for?
    Many Thanks
    Marcus
  2. Jase
    Jase
    Mar 16, 2001
    10,937
    United Kingdom
    +3,290
    If you have a 5.1 setup then plug the rears into the Surround A terminals. If you want 7.1 then you'd plug your two additional rear speakers into the Surround Back terminals.
    With regards to the EQ you can either leave it as is or manually change the speaker sizes. I manually changed mine to all small, all bass to sub after the auto EQ set them all to large.
  3. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,930
    2
    The Fylde Coast
    +13,684
    You could always check the distances which the EQ calculated and compare to an actual physical measurement.
  4. BUFFY FAN
    BUFFY FAN
    Jan 6, 2005
    142
    Huddersfield
    I think you're supposed to set the sub cross-over before starting auto calibration. Mine is set to 80hz. It set all my speakers as large but I have just left the front left and right as large. Everything else small. You can change the mode. mine is set to normal. I thought this had more punch for movies than the others. When playing music I just switch it to pure direct though which bypasses the tone/bass settings etc. Have fun.:)
