3805 or 3806?
Discussion in 'AV Receivers & Amplifiers' started by pixelated, Nov 4, 2005.
  1. pixelated
    pixelated
    Feb 12, 2005
    1,847
    +94
    Hello everyone
    Just got off the phone from my local Sevenoaks and asked 'em the major differences between these two models. Apparently it's mostly you can run HDMI connections into it whereas you can't on the 3805?
    Is the 3806 worth the extra? I.e. the 06 is about £1000, if in theory you could get a 3805 for 500-600 quid, would you do that instead? I have a Denon 3910 and looking to get some monitor audio radius speakers and not sure what to do!
    Thanks :thumbsup:
    Stu
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The 3806 would be nice but without the need for HDMI your only real reason for getting one given the choice are some improvements to auto setup and bragging rights. You will have DL3 which made all the difference for me (3805 first, got my 3910 after) and pretty much the same sound quality. Cosmetically they are almost identical so no reason to go one way or the other. I would go 3805. Bragging rights are good though! :D
  3. pixelated
    pixelated
    Feb 12, 2005
    1,847
    +94
    Yes, they flippin' are ;) lol Ahh it's tough.
  4. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    if you can get the 3805 £300 or more cheaper than the 3806 and dont need HDMI switching, then go for the 3805.....if the 3805 isnt being sold much cheaper than the 3806, probably might as well future proof yourself with a 3806....
  5. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    'Future proof'. I avoid using that phrase because in the constantly evolving world of Audio-Video it is the least viable reason why anyone should upgrade.
  6. Tejstar
    Tejstar
    Dec 4, 2002
    23,034
    London
    +1,157
    If you have no intention on jumping on the HD bandwagon in the next couple of years then go for the 3805. By that time there will be better amps available and probably with all the necessary HD codecs.
    However, the 3806 will give you flexibility of making that choice if you want to go HD without worrying about buying a new amp.
  7. pixelated
    pixelated
    Feb 12, 2005
    1,847
    +94
    Thanks for the replies :)
    Well seen as though I've got the PV500 with it's HDMI input, and Sky HD looming I wouldn't mind having more HDMI connections available to me (My PV500 one is being used by the 3910... ) But then again I don't plan on getting an xbox 360 anytime soon, but I'd like to have the option of getting Sky HD... I read in What HiFi? there's a little box out that connects to HDMI connector on the TV and gives you two without any noticeable loss in quality - what do you reckon of this?
    God I hate it when manufacturers release new products ;) hehe
    Stu
  8. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    as i said in my post, if the price difference isnt all that much then future proofing with HDMI is worth it......
    the emphasis being on the difference in price, if they only offering the 3805 £100 or £200 cheaper, and the sound quality of both was the same more or less then i'd take the one with the HDMI because more and more things will be released with it as an option nowadays.........but if it was a good £300 or more difference then i'd take the 3805 and get a HDMI switch box....lol
    (unless of course the 3806 made a good difference to the sound quality, then i'd go with that if my budget was ok for it)
  9. zerolight
    zerolight
    Jan 29, 2004
    239
    Glasgow
    +9
    A good hdmi switch box with hdcp is £250 (gefen). So to my mind that brings the difference in price down to not a whole lot. I'd go for the 3806. Actually I did.
    FYI the xbox360 uses component not hdmi.
  10. Welwynnick
    Welwynnick
    Mar 16, 2005
    7,286
    Welwyn, Herts
    +943
    Just because an AVR handles HDMI doesn't mean it does everything you want. First question you have to ask is what version isit compliant with - 1.0, 1.1, or 1.2? If it doesn't take V1.2, you will have to use analogue or iLink to connect SACD, and that's not what it all about.....
    Secondly, what input resolution is accepted and processed? Many of them only take 480i, and that's a bit short-sighted. Just because it has HDMI connectors does mean it's any use. This sort of information isn't always very forthcoming.
    Nick
  11. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    3806 is 1.1 if i remember correctly.....
    so no SACD, but it will do DVD-A
  12. witters
    witters
    Jul 13, 2000
    12,794
    Yorkshire
    +306
    It's Denon Link 3 though isn't it? I thought that was SACD as well?
  13. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    That may have been what you meant, but it isn't exactly what you said. ;) While I fully understand your point, I would not be looking for a price differential of as much as £300 to justify the older option. Especially as the 3806 is still essentially untested (and we know Denon often use early adopters to iron out their little idiosyncrasies). There is a lot to be said for tried and tested maturity. I know, I'm old! :D
  14. jwramsay
    jwramsay
    Sep 7, 2004
    1,651
    West of Scotland
    +76
    3806.
  15. zerolight
    zerolight
    Jan 29, 2004
    239
    Glasgow
    +9
    it takes in 480i/p, 576i/p, 720p, and 1080i and ouputs them again. it also up converts same resolutions in component to hdmi. i think that's pretty useful if your TV has just one input which can take either HDMI, DVI-D, or Componet. Like my Philips. ;)
    It's currently HDMI 1.1 compatible. According to the USA manual it does SACD CD area. Whatever that means. UK website also says it's Denon Link, 3rd Edition, SACD ready. Whatever that means.
  16. Smurfin
    Smurfin
    Aug 13, 2002
    21,475
    +4,404
    So has anyone actually got a 3806 yet?
  17. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    HDMI 1.1 means Dolby Digital, dts, pcm and CD. I am not sure if DVD-A is included. A hybrid SACD will include a CD layer.
    DL3 will carry all sound formats at full resolution when connected to a similarly equipped source (3910 and above). It is Denons 'equivalent' of iLink.
  18. Jase
    Jase
    Mar 16, 2001
    10,960
    United Kingdom
    +3,435
    HDMI 1.1 also carries DVD Audio. :)
  19. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    i was talking about HDMI, the Denonlink is a separate plug, but yes, verion 3 Denonlink does DVD-A and SACD multi channel....
