I have recently moved house and brought the denon 3805amp +3910 dvd player.
I am currently using the following speakers :-
Which were used on my old Pioneer VSA-701 amp.
Front L+R KEF k SERIES Bookcase type speakers.
Center Jamo 100
Rears Cannon SV15???
Question is I want to buy a sub/sat system and have short listed the choice down to genies/ cubes/ b&w mt-30. And just to throw a spanner in the works, would in be worth spending loads of money of the mission e83 elegance system? should I even listen to them?
I like listening to music but it will be mainly for film use, is there any where Between Brighton and London(central/west end) where I could audition all three of the above and make a purchase
My room is 21ft long by 13th foot going down to 10ft but I have an awkard cupboard which means that it is slightly L shaped. I Currently project a lovely 10ft image from my 5700 infocus on the wall, but the rear speakers will only be about 15ft away from the screen on the side walls of where we will be sitting.
I do not want to have massive speakers any suggestions on where i can listen to all three and which ones do you recommend with the denon 3805?
thanks for listening.
regards,
Paul
Center Jamo 100
regards,
Paul
