3805 & Ipod
Discussion in 'AV Receivers & Amplifiers' started by Ridcully, Feb 12, 2005.
  1. Ridcully
    Ridcully
    Feb 16, 2002
    358
    28
    +35
    Silly question but is there a way to connect an IPOD to a 3805 and if so how ?
  2. neal666
    neal666
    Dec 29, 2004
    196
    +3
    does the ipod have a optical port?
  3. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
  4. Ridcully
    Ridcully
    Feb 16, 2002
    358
    28
    +35
    Have one of the leads that PArklife has mentioned but the sound is very quite if I feed in to the CD audio ports. Was wondering if I should ffed into the external 6.1 inputs but wan't sure
  5. Lester
    Lester
    Mar 4, 2001
    243
    Oop North
    +10
    If you connect it via the headphone socket on the iPod, then the volume is gonna be affected by the volume setting on the iPod.
    If you connect via the docking station (socket on the back) then it should be at line-level and work well with the amp. I do it this way and it sounds fine.
  6. Ridcully
    Ridcully
    Feb 16, 2002
    358
    28
    +35
    Slight problem. Mine did not come with a docking station, so head phone socket it is. :(
