3805 Front Panel Display Problem
Discussion in 'AV Receivers & Amplifiers' started by buckyb, May 15, 2005.
  1. buckyb
    buckyb
    Hello, I'm a long time reader and a first time poster. I have a little problem with my 3805's front display panel. It suddenly turned off. I don't know if I accidentally hit a button or not but I could not figure it out (read the manual and all). Everything still works and the display comes back on when I do a command. I know that if you go to direct mode that it will shut the display off. Tried to turn the direct mode on and off but the display will eventually turn off. Not sure if there is an easy fix or somethings wrong with the receiver but I would totally appreciate any thoughts or suggestions.
  2. hooch
    hooch
    There is "dimmer" button at the bottom of the remote, you probably turned your display off.
  3. buckyb
    buckyb
    That was it Hooch. I appreciate the help!!
