3805 - DD/DTS - LFE Settings ???
  • Thread starter Deleted member 30535
  • Start date
D
What is the relationship between SW levels as set in calibration (- 3db in my case) and the LFE deafult level of 0db in DD/DTS modes? Is there any rationale in this level or should it be changed to reflect the SW level I have calibrated to?
:confused:
:smashin:
Jase
Leave the LFE settings on their defaults. This is the LFE content so shouldn't be touched. The SW channel is the overall volume for your sub output.
D
Except, apparently, with DTS music as the source. The manual suggests a setting of -10db for the LFE. Cheers all the same.
Jase
Yeah, forgot about DTS CD's. :suicide: They're usually mastered 10db hot.
D
Geez, it was no wonder the whole house shook with a DTS rendering of PInk Floyd's The Wall". IT sounded like a jet aircraft was about to land. :eek:
