3805 average volume
Discussion in 'AV Receivers & Amplifiers' started by Roguey, Oct 7, 2004.
  1. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    hi, i got an new 3805 and wondering what is the average volume people set it to? so far it looks around -10db for flims, plus mine only goes upto +6db top, how come?
    many thanks
  2. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    You can't really compare the dB levels reported by the Amp unless you are listening with the same speakers as the other person. The output sensitivity and impedience of the speakers will affect the actual volume produced.
  3. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    depends on how you have set up your channel levels. assuming that the highest volume on the 3805 is +12db and you have set the channel level for your centre speakers at +8 db then the highest volume your receiver can go to is +4 db.
    I had a 3801 and i was stumped for a while until i read the manuals!!
    So the for is quite straight forward. Maximum volume= +12db -( any db's set for any of the six channel )
    Hope this helps
  4. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    ah, i saw them set to +12db front/left/center so i put them back to 0db, should i leave it at +12db for each channel then? is that ok?
    i noticed my direct mode was louder, looks like i had it at +12db /channel and the dvd and that not.
  5. kumamoto
    kumamoto
    Sep 2, 2003
    1,151
    38
    Watford
    +17
    that ok,you can leave it at 12 db for all channels. You should set the channel level to any level that is suitable for your setup.
  6. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    ah, thanks.. so with the max volume saying its max is +6db and all channels set to +12db (minus the subwoofer) then what would u say is the max volume before it might get into overdriving (master vol)? 0db vol? higher? lower? (ie. what volume should i say is its very max? even if it can go higher)
    i think that made sense? lol
    thanks for ur help :)
  7. Ged
    Ged
    Apr 29, 2002
    943
    +24
    I have the 3802, the max volume is + 18 db with the speakers at 0 in the level set up.
    So if one speaker is set above 0 it drops the max level.
    What you need to do is set the levels using a sound meter. This will compensate for different speakers, you set the levels to attain a neutral recording. This may mean a different setting for each speaker to attain this.
  8. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Yes you can you need to set the levels up with a spl meter so that 0db is at reference level,do a search there's plenty on this subject.Saying that you listen at -10db means nothing unless you have set the levels up correctly.I very rarely go past -25 when watching dvd's unless i'm showing off to friends.The numbers on the front mean nothing unless you set them up to mean something.
