3805 Auto Surround, Memory & modes: what a pity..
Discussion in 'AV Receivers & Amplifiers' started by Mr Incredible, Oct 23, 2005.
  1. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,568
    The Fylde Coast
    +12,916
    that although the 3805 can memorise the surround mode for each source, and can remember the mode settings, it does not allow different mode settings for each source.
    Why is this a pity? Well, when I listen to DTS audio CD I use the CD as source (COAX1), I turn down the LFE to -10db for the DTS Surround mode because DTS audio cd's are mastered 10db hot on the LFE. The Denon manual recommends this setting.
    The "problem" is then that if later or another day I watch a DTS movie with DVD as source (OPT1), the LFE should be at 0db for that mode. I now have to adjust the mode settings back to the normal ref level. A bit of a PITA.
    I can't believe it would have taken up that much more memory to have the 3805, in addition to remembering the source mode which was last used on each source, have it also remember the mode settings for each source.
    Just a (reasonable) suggestion!
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,439
    United Kingdom
    +1,820
    Unfortunately the Denon's class DTS/Dolby as one mode. It should however, store seperate settings for analogue and digital signals. Seems to be a bit hit and miss on my Denon with this though.
  3. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,568
    The Fylde Coast
    +12,916
    I've put a call into Denon in the UK to see if they can unravel the mystery!! Watch this space......
