3805 Auto Calibration
Discussion in 'AV Receivers & Amplifiers' started by Mr Incredible, Aug 24, 2005.
  1. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,568
    The Fylde Coast
    +12,916
    Within the last couple of weeks I've realised my long time burning desire to get a HC set up. See my tag line.... :)
    As my Mains are relatively "meaty" speakers I thought I'd see how the bass output was before thinking about a sub. Also my plan was to bi-amp the front as well. I realised that I couldn't have the bi-amp set up for Auto set up, so just moved the bananaplugs from the Back Surround terminals (Assigned Zone 3) to the Main L/R plugs.
    Anyway, I ran the Auto set up and the 3805 (although no sub, crossover was set to 40Hz), set all speakers to LARGE.
    I then put the cable back to bi-amp configuration...........The bass response has been awesome (+2dB on the VDP settings for bi-amp), with house thudding thumps that SWMBO is asking I turn down. :devil: I am thinking that a sub may be overkill.
    However, one thing I have been suprised by is that I need to have the amp on 0dB to get a sound level whcih I feel is acceptable in my 2400 cu ft room. The seating position is 4.9m from the front speakes (thank God for my 50" TV !!).
    Does this set up "sound" right?
    :smashin:
  2. shodan
    shodan
    Dec 11, 2001
    11,595
    shoeburyness
    +6,522
    If you had a decent sub I would put money on you not needing to go that loud to get an accetable sound level. Personally I've found that I gudge "loud" and "too loud" but either how much bass I'm experiencing (or in my set up, how much bass distortion I'm experiencing) or how brash the speakers start sounding!!!
    Simple answer? Get a kick ass sub!
  3. matobinder
    matobinder
    Aug 24, 2005
    5
    One thing, in my opinion, is your mains sound better with a sub. Meaning, they go to work more on the rest of the audio spectrum, and you can leave the low end bass to the sub. My vote is always for Velodyne subs, they don't cost a boat load, and sound pretty nice. I have a Velodyne matched up with the rest of my B&W 60x Series 3 speakers.
  4. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,568
    The Fylde Coast
    +12,916
    So are your speakers set as "SMALL" and what crossover level do you use?
  5. Wild Rumpus
    Wild Rumpus
    Mar 30, 2005
    138
    Erskine
    I'm using pretty large speakers as Mains (Linn Ninkas) with a subwoofer (Ruark LogRythm). I just let the Auto setup take care of everything and I'm pretty happy with the sound. The Auto-setup set the mains as "Large" and I think that the crossover is at 40hz. It sounds good on movies and music. Surprisingly, adding the sub increased the sense of "air" and clarity on music as well as added thump when required.
  6. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    Yes, it's amazing what a sub does to the top end. By adding that just bit of
    extra weight down there, it really opens up the whole range.
  7. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,568
    The Fylde Coast
    +12,916
    What recommendations would anyone suggest for a sub to match my kit / room? And placement?
    [​IMG]
  8. Piers
    Piers
    Dec 11, 2002
    1,991
    Cheshire
    +229
    I am using a Velodyne CHT-15R in a slightly larger room - you might get away with a the smaller 12" model. A quick check on your room dimensions suggests that 7 foot (and multiples thereof) from the front wall should be avoided
  9. Timbo21
    Timbo21
    Dec 23, 2004
    4,632
    3
    London
    +315
    You'd do better on the subwoofer forum. Also, how much you are willing to pay.
  10. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,568
    The Fylde Coast
    +12,916
    <£500. I am considering a S/H route too.
