3805 and osd
Discussion in 'AV Receivers & Amplifiers' started by john R1, Jul 29, 2004.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    how would i get the on screen display to work on a 3805, have at the moment pw6b with one component board for dvd and one scart board for telewest cable
  2. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    Whats a pw6b? I take its a display.
    If so feed all video devices to the 3805 and connect the monitor out on the 3805 to you display. Now all of your video devices will be up converted to component thanks to the nice people at Denon :)
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    With your current kit all you will need is another component video cable. Connect the DVD player to the component inputs on the receiver then connect the component monitor out connection to the component input on your plasma display. You can leave the Telewest box connected to the screen via scart as this will still give you the best picture from it.
