3805 an additional speaker setup
E
erez
I got 3805 that runs today in the living room with 5.1 speakers.
I want to install another 2 speakers in the balkonu and that i can control to listen in the living room or in the balkony for the same sources . i dont need another IR link only speakers ( 2 stereo only ) .
is it posibble ?
tia
Erez
Jase
You can assign the Surround Back amps to power a pair of speakers in another room. Bear in mind only analog sources will work though.
D
Deleted member 30535
Jase, if erez only wants to listen to the same source on the mains or the second pair, then if he wired up as if for bi-amping, then the source could be digital as the pre-out would provide the analogue signal for the 2nd pair? A bit of a kludge, but who knows!!
Jase
Not sure to be honest as I've not tried that.
D
Just thinking about my bi-amp set up, the bass drivers are driven by the analogue signal from the pre-out to the VDP (as per audioholics set up guide for bi-amping) and hence works when the source is digital. So if instead of taking the bi-wire/bi-amp connections to the bass drivers on my speakers, I just routed them another pair of speakers then it would work. IMO of course!
D
dmorris65
I have the same problem. I want to send analog and digital input sources to a pair of speakers on my covered patio.
I had them connected to Surround Back/Multi Zone & got no sound when I set Zone 2 up in POWER AMP Assign menu. Must have been because my source was digital. I will want to send stallite radio to those speakeres so it's a delimma.
What I did was connect the patio speakers to Surround "B" then set them to only work with 5 channel stereo (A+B). Now I can listen to stereo on the patio from the same source but the problem is I have to have the main room on 5 channel stereo (can't only have 2 channel stereo - mains only).
Any suggestions?
G
ghymer
i run ipod into the cd input for stereo music, will i be able to use back speaker as zone a and play it? or is that a digital no-go?
