3804 setup issues - help!!
Discussion in 'AV Receivers & Amplifiers' started by gweru, Aug 28, 2006.
  1. gweru
    gweru
    hi there - recently bought the 4306 - have two inputs - cd/dvd and satellite - both via component and optical audio - output to a lcd tv and new set of anthony gallo ref 3.1 speakers.
    Have gone through the set up options of the 4306 - and all seems fine - satellite works fine - both video and audio - but on the dvd - video is fine - but no audio! - can't figure out what the issue is?
    if anyone can shed some light on what I may have done wrong - it would be appreciated.
    Many thanks
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,238
    2
    137
    Airdrie, Scotland
    +1,054
    I don't know the 4306 but, having a 2805, I would guess that perhaps you have not assigned your inputs to the relevant Optical connectors.
    Cheers,
    Martin.
  3. gweru
    gweru
    Hi Martin - thx for the reply - have checked the settings - set to opt 2 - which is the correct input - still struggling - have re-done all the settings - but still no luck
  4. mjcairney
    mjcairney
    Oct 26, 2003
    7,238
    2
    137
    Airdrie, Scotland
    +1,054
    In that case, assuming your source equipment and optical cables are okay, I'm struggling to help you any more. Hopefully someone else might have an idea.
    Cheers,
    Martin.
  5. Jase
    Jase
    Mar 16, 2001
    10,862
    United Kingdom
    +2,872
    Try assigning it to another Optical Input and see what happens. Any chance you can try another optical cable in case it's damaged?
  6. gweru
    gweru
    thx - tested the cable on the working channel - and all OK - just thinking - would there be an issue on the dvd side? - the dvd works when plugged straight into the tv - but not sure if there is a subtle setting that needs to be tweaked?
  7. Jase
    Jase
    Mar 16, 2001
    10,862
    United Kingdom
    +2,872
    Is the DVD's digital output enabled and set to BITSTREAM?
  8. gweru
    gweru
    hi there - just had a look - and all seems OK - using a Sony DVP-S735D - but I am not sure what the settings should be - have just tried a RCA connection and that too does not work.
  9. Jase
    Jase
    Mar 16, 2001
    10,862
    United Kingdom
    +2,872
    Seems the player might have a problem in that case. Sony's tend to have a few setup options with regards to outputs, just need to make sure the digital outs are on and that Dolby Digital and DTS are enabled.
  10. gweru
    gweru
    thx for that - will check all the dvd settings again and try and sort it from there.
    cheers
  11. BandWidthJunkie
    BandWidthJunkie
    May 27, 2006
    982
    46
    Nottinghamshire
    +159
    On page 13 of the manual for the Sony DVP-S735D it states that when you connect an audio component with a builtin Dolby Digital decoder you need to set "DIGITAL OUT" in "AUDIO SETUP" to "ON" and then set "DOLBY DIGITAL" to "DOLBY DIGITAL" in the setup display (page 65).
    Have you done this?
    It also says set "MPEG" to "MPEG" if the audio component has a builtin MPEG decoder and "DTS" to "DTS" if the audio component has a builtin DTS decoder.
    Page 65 goes into greater detail.
    Hope this helps.
  12. gweru
    gweru
    Hi - thanks for the feedback - have checked all the settings - and all OK - and I can now get audio via a normal rca connection - so good news - but still can't get audio via the optical cable.
    thanks for the input
