3803 - Video inputs/outputs
Discussion in 'AV Receivers & Amplifiers' started by Bazza1400, Apr 11, 2005.
  1. Bazza1400
    Bazza1400
    Apr 10, 2005
    17
    this is a question that I should prbably know the answer to but here goes.
    I have a Sony TV with 1 No. RGB scart socket and 2 No. S Video Scarts
    Reading the 3803 manual I think it suggests that I can connect from the component out on 3803 to the TV ( 3 phono's to the RGB Scart?) and I can then use the inputs available on the 3803 to do the following :-
    Use the component in to the 3803 to connect to my DVD 2900 DVD player component output?
    Use one of the S - Video inputs to connect my Sony Play Station (would this upmix the signal to component/RGB? and pass it through the component out /RGB scart into the TV?)
    Use one of the S Video inputs/composite inputs for my music player it has an S video output/composite output (would this upmix the signal to component/RGB? and pass it through the component out/RGB Scart into the TV?)
    What I am really trying to do is to get the very best signal from all of the components in the system - so any other suggestions would be helpful (other than having an RGB scart switch)
    Many thanks for your help
    Bazza
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,433
    United Kingdom
    +1,803
    Component and RGB are different things. Your TV will be expecting an RGB signal but the Denon will be outputting a Component signal so you won't get an image. If you want to run everything through your amp then to get it to work with your TV you'll have to use S-Video for all inputs and outputs. Another option is to connect the DVD player directly to the TV via RGB Scart and the Playstation and music player directly via S-Video cables.
