3803 v 3805 Question
Discussion in 'AV Receivers & Amplifiers' started by ianharvey, May 18, 2004.
  1. ianharvey
    ianharvey
    Dec 1, 2003
    57
    Now that the 3805 is out and about, the 3803 seems very good value. What are the main differences here?
    I understand that the 3805 can sound delay (for lipsynch issues) on a per input basis, can the 3803 do this?
    I'm thinking of pairing this with some cheapish speakers to start with (as I don't want to buy a separate lipsynch solution) and buying something better in c. 6 months.
    Any advice on this one, looking to spend as little as possible now, so that I can spend more later?
    TIA for any comments.
    Ian
  2. ianharvey
    ianharvey
    Dec 1, 2003
    57
    I should add that we do listen to a lot of music as well as TV (very, very little DVD use).
    I do have a pair of Tannoy DC1000s (for those old enough to remember their dual concentric design) can I still use these or should I chuck them?
