3803 owners help please
Discussion in 'AV Receivers & Amplifiers' started by Stereo Steve, Sep 2, 2004.
  1. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    I wonder if any 3803 owners out there would be kind enough to do a quick measurement for me. I used to own one and liked it and am now looking for another but I need to know how deep it is in total. That is, from the edge of the volume control to the end of the power lead plug. So, in other words, whats the minimum depth cupboard it will fit in with all the leads plugged in (I think the power lead is probably the sticky outest)
    I would be eternally gratefull if somebody could do a quick measure for me.
    Cheers.
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Hello Steve... Mine is in a cabinet so it's a bit difficult to get at but I've just measured 46cm minimum, but 48cm to be safe... I've got the upgrade itch myself... ;)
  3. Taz
    Taz
    Steve,
    With my big fat component cable.. (not flexy at all!) im gettin 499mm.... to the power lead I get 404mm
    HTH
  4. Taz
    Taz
    Width 434mm
    Height 171mm
    Depth 416mm
    From Denon :lesson: :)
  5. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Do me a favour taz,could you measure the depth without the sticky out bits ,i've asked before but never got a reply.
  6. Taz
    Taz
    That will be the dimensions above from Denon...no? :)
  7. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    You tell me you have the amp and tape measure,most manufactures include the sticky out bits.
  8. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Thanks guys. Taz, you say it's 404mm to the power cable and yet Denon state 416, which I assume is without the power lead plugged in. Is the 404 a typo?
  9. Taz
    Taz
    the power lead is wired in type, not a plug in one. :)
    I'll check again when i get home.
  10. Taz
    Taz
    just had a thought, that 416 will be to the back of the binding posts for the speakers! so yeh 416
  11. Taz
    Taz
    bob, ill do that measurement for you later on.
  12. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Ah yes of course, thanks. I assumed it would be an IEC but I remember now that it's hard wired.
    Thanks for your help, I appreciate it.
  13. Taz
    Taz
    Bob, 375mm just the body of the amp, not the volume control or rear conex.
  14. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Cheers taz,i'll check if one will fit my rack when the wifes not looking ;)
