3803 and 2900 delay settings
Discussion in 'AV Receivers & Amplifiers' started by gpa, Oct 6, 2003.
  1. gpa
    gpa
    Having just recieved my new silver 3803 and 2900 I am a little confused about the delay settings. both the dvd and the 3803 have inputs for distance from listener, do i adjust both so they are the same or is this incorrect. The reason i ask is i wonder if the dvd will send the delay to the 3803 and the 3803 will add a further delay.
    Am I making any sense LOL!!!!!!
  2. Jase
    Jase
    Mar 16, 2001
    9,530
    UK
    +930
    The 3803 delays are for using it's decoding for Dolby/DTS etc and you would feed it a digital signal (either Optical or Coaxial Digital) from the 2900.
    The 2900 delays are for it's 5.1 analogue outputs and it's onboard decoding for Dolby/DVD Audio etc etc. The delay times will not affect the digital outputs.
    You won't get a multiple delay affect from one to the other.
