3802 speaker level adjustment?
Discussion in 'AV Receivers & Amplifiers' started by plb, May 18, 2002.
  1. plb
    plb
    Sorry if this has been answered before but ref my 3802 is it possible to individually set up the outputs of the various speakers in DPL2, DD and DTS.
    I ask as I have found that if you set the speaker outputs say using DPL2 this also becomes the output levels for DD and DTS?
    Ideally I would like to be able to fine-tune the various outputs when using the above sound formats but the manual is not very clear in this respect.
  2. bob007
    bob007
    Think DPL II, DTS and DD share the same levels, but some of the other sound options can be set individually, Direct, stereo and widescreen.
    bob
