3802 owners leave it on or not?
Discussion in 'AV Receivers & Amplifiers' started by neilneil, Mar 13, 2002.
  1. neilneil
    neilneil
    Jan 2, 2002
    720
    28
    +39
    Just out of interest how do other 3802 users leave their amp when not in use.
    I ask this because if you press the off switch on the front of the amp then it compleatly shuts off. However, it also has a standby mode which operates like a video where you can wake it up from the remote control.
    Is the amp designed to be left in this state for periods of perhaps days or should you switch it off compleatly.
  2. bob007
    bob007
    Always leave mine in standby mode unless i am away on holiday.......
  3. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    My A1SE is left in standby over night.
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Mine is switched off totally when I´m not around as if its Standby Mode and then we have a power cut (fairly common over here!!) it turns itself back on when the power comes back.
    Not a good thing to happen especially in the summer when the temp is 36 degrees and upwards (in the shade!!:eek: )
    Nows ok as its "only" 25 degrees!:D :p
  5. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Jase, So if you click into standby mode with the remote, if you have a power cut, the unit comes back fully on? All guns blazing?
    I suppose this explains why you can get out of standby mode by switching fully off then back on.
    Mark
  6. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Mark
    Yep! you got it!!
    Its a minor flaw on one hand but a useful feature on the other (if you lost or broke the remote for example).
  7. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Not a good thing to happen especially in the summer when the temp is 36 degrees and upwards (in the shade!! )
    What's wrong with your aircon ;)
  8. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Cant afford it, spent all the cash on Home Cinema!!;)
  9. denonman
    denonman
    I leave my AVR-3802 on standby, but i would turn it off if i was going away as i do with all my electrical stuff, in case off electrical storm etc...
  10. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    23,408
    2
    In a secret location with Jennifer Lawrence
    +10,342
    If you unplug the 3802 from the mains for a while does it lose all the settings that have been made? or has it got a backup memory? :confused:
    Greg
  11. bob007
    bob007
    The unit has a memory storage of 1 week when unpluged from the mains.
