3802 or ????
Discussion in 'AV Receivers & Amplifiers' started by gary., Oct 14, 2001.
  1. gary.
    gary.
    Hi.
    Sorry its another what to buy question.
    After a bit of reading my mind was
    made up on the Denon 3802.But....
    The A-10SE is only £150 pounds more.
    Do I go for the all formats known to man
    3802 or the I guess better quality sounding
    A-10SE?
    Over to you guys.
    Gary
  2. MarkB
    MarkB
    Oct 29, 2000
    737
    Suffolk, England
    +26
    Gary,
    That depends on what you want and what you consider a priority.
    If sound quality is your main concern then the A10SE will be your best bet. If decoding all surround formats from dts and Dolby is your priority then it's the 3802.
    Personally, I'd go for the latter.
    Mark
