3802 optical input problems
Discussion in 'AV Receivers & Amplifiers' started by Zog, Dec 9, 2003.
  1. Zog
    Zog
    Aug 16, 2001
    433
    Manchester
    +5
    Finally decided to connect my PS2 up via the optical port.
    Using No. 3 I just cant get sound. I've swapped leads around and tried different inputs and it works fine, so I know there is an output from the console and that the lead is fine.
    Have I missed something here, or is that input buggered !
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    Couple of things to check.
    1. When you connect your PS2 to another digital input with the same cable you get sound, yes? Are you sure the sound is being transmitted digitally (no analogue feeds present)? Bear in mind that the PS2 optical output is not enabled by default and has to be manually switched/configured.
    2. What menu options are there on a 3802 for configuring Digital inputs. Is no. 3 maybe tied to another input (possibly an analogue set) or a particular sound format rather than auto-detecting. Again as I don't have a 3802, sorry if this is rubbish.
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
    Have you got the input set to auto?
  4. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,740
    2
    In a secret location with Jennifer Lawrence
    +9,526
    I had this exact same problem on my 3802. gave up in the end and just used the no 2 input.
    Everything was set correctly on the PS2 side and the 3802 input was set correctly (AFAIK) aswell. So I would be interested to know what is the problem here.
    Greg
  5. S H A D O
    S H A D O
    Mar 16, 2001
    10,436
    United Kingdom
    +1,820
    Make sure it's assigned to the correct digital input. You have to do this at the Digital In Assignment section which is accessed from the main Onscreen Setup Menu. :)
  6. Zog
    Zog
    Aug 16, 2001
    433
    Manchester
    +5
    I have assigned the relevant input "optical 3". and I know that the PS2 is outputting optical coz I can see it and also because when I change things round I get sound.
    There are no analogue feeds as the only other cable connecting PS2 to the AV equipment is an S-Video lead.
    The more I think about this , the more I am convinced that the optical port is buggered. :confused:
  7. S H A D O
    S H A D O
    Mar 16, 2001
    10,436
    United Kingdom
    +1,820
    You could try a Processor Reset to see if that cures the problem. Hold down the AUTO & PCM buttons whilst turning the Power On, hold them all for a few seconds and the display will flash and reset everything. Make sure you write down all your settings beforehand e.g channel levels, delay distances, speaker settings etc.
  8. Zog
    Zog
    Aug 16, 2001
    433
    Manchester
    +5
    Finally sorted this out.
    There is a facility to save a particular set of parameters for each input channel.
    I was using the CD input which had previously been set to expect an analogue stereo input (this saved me the time of switching off the PLII sound every time I played a CD)
    Set this to optical....... and bingo PLII was back on the menu.
    This menu was accessed via the remote. Don't ask me where I found it it took me weeks of playing around.
