3802 Dolby EX Question
Discussion in 'AV Receivers & Amplifiers' started by Brigadeer, Aug 20, 2002.
  1. Brigadeer
    Brigadeer
    Am I right in assuming that when decoding EX on the 3802 - you set the amp to 6.1/7.1 (the display says 6.1 surround)...but the back channel light does not come on ???
    Is this correct ?
  2. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,628
    United Kingdom
    +2,233
    You´ll get 6.1 surround on the front display, the Surround Back Output indicator will be lit but not the Signal Detect light (some discs will show it, but not many though!!).
  3. Brigadeer
    Brigadeer
    Jase -
    Can you recall which titles ?
    (I have tryed ones like Phatom Menace, Perfect Storm, Austin Powers 2 etc.)
    Thanks.
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,628
    United Kingdom
    +2,233
    It tends to be mostly the DTS ES Discrete titles that have the flag. Gladiator, Rush Hour 2, The Haunting Region 1 etc. I think Atlantis R1 has the flag on its Dolby track. Terminator 2 also, if I remember rightly. There are´nt many! :(
  5. Brigadeer
    Brigadeer
    Thanks Jase - I'll try T2...
    It seems a shame though that other titles which have matrixed rear channels (like Jurassic Park 3 - dts 6.1 matrix) highlight the back channel indicator - but dolby ex matrix discs don't !!
    Perhaps a design / flag fault ??
  6. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,628
    United Kingdom
    +2,233
    Laziness at the encoding stage I would say. Shame really, as all amps/receivers with the AFDM (Auto Flag Detect Mode) have a fairly useless feature.
  7. digitalsafari
    digitalsafari
    Jul 23, 2002
    728
    46
    Devon
    +123
    We can't use the EX flag on DD (extended metadata) because some old DD decoders freak out, which is why no new titles or Sky Digital have the EX flag set.
    The old DD decoders are from one manufacture and is a desgin fault as the DD spec is clear about data for future use.
    Spammonkey
    DVD Producer
  8. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,628
    United Kingdom
    +2,233
    I stand corrected on my comment.
  9. Whatts
    Whatts
    My (Dutch R2) DD EX copy of Lord Of The Rings lights up the Signal Detect light on my 3802...
    But I thought I just saw 'Dolby D' on the display (not 6.1).
    Jase, as Resident Denon Amp Specialist, got any idea why?
    Also, if I'm not mistaking the DTS-ES version of Se7en also has the flag set correctly (so also lights Signal Detect)...
    - Tom -
  10. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,628
    United Kingdom
    +2,233
    I´ve only got the R1 version of LOTR, don´t recall seeing a signal detect light, mind you I didnt really look, I just set the amp to Dolby EX (bit different on my Denon). I´ll check later.
    With regards to seeing Dolby D on the display, you have got the Surround Back speakers switched on have´nt you? Sorry if this seems a daft question!
  11. Whatts
    Whatts
    Jase,
    Yep, SB speakers are on.
    I wasn't sure if 6.1 should be on the display so I didn't pay much attention to it. I'll also take a look tonight...
    - Tom -
